Pretty much OT: Ordering CAT5 cable online
Apr 10, 2005 4 Replies
Jump to replies (4)
Pretty much OT: Ordering CAT5 cable online open original image
Sorry for the OT to a WIRELESS newsgroup, but this is a real easy one, and I figured since you guys have probably done so much research on it. I can save myself an hour or two sourcing from Google.
Anyway, simple question: Where is the cheapest and best place to buy Cat5 cable online? I know I can find it cheaper than at my local store.
Thanks!
Ryan
Try
or
Depends on what you are using for a "Local store". Try going to a contractor's General Supply, or wholesale/Retail Electrical supplies store and asking. Generally I have found their prices tremendously cheaper, and no shipping either.
Ed
I use Screwfix or a specialist cable supplier when I want 100 metre drums, otherwise maplin for patch cables etc. You can save a few pee here and there by shopping around for wall boxes etc.
Taking a moment's reflection, The Chairman mused: | | Anyway, simple question: Where is the cheapest and best place to buy Cat5 | cable online? I know I can find it cheaper than at my local store.
You can try Cables and More ...
