I want to connect an existing desktop to my current wireless router. My daughter's laptop has given up the ghost and I'm hoping to use her PCI card for the desktop. Can I connect it to the desktop via a PCI card reader through a USB port?
PCI Card Reader?
Jan 03, 2005
You must mean a PC Card (aka PCMCIA or CardBus) reader. They do exist. Linksys, Netgear, etc. sell their own for about US$40, last time I looked, and you can probably find generic models a bit cheaper. However, all the ones I've seen install in a PCI or ISA card slot in a…
Read the full replyYou must mean a PC Card (aka PCMCIA or CardBus) reader.
They do exist. Linksys, Netgear, etc. sell their own for about US$40, last time I looked, and you can probably find generic models a bit cheaper. However, all the ones I've seen install in a PCI or ISA card slot in a desktop machine; they don't make USB variants that I'm aware of.
FWIW, you'll spend the same or less buying a new Wireless USB adapter for yourself than trying to find an adapter to make use of your daughter's notebook card. You can find new 11b USB adapters for US$20-$30 (after rebates).
good luck, Jonathan
Laptop with a pci card? don't you mean pcmcia or cardbus? No idea on whether it can be used on pc as I don't know if you can buy any hardware for a pc to read them...
Daniel
