Sending digital video from my PC to my TV: How difficult can this be?
Nov 06, 2004 7 Replies
Jay Chan
You may want to post your message in newsgroup. There was one person in that newsgroup who had tried using wireless connection to stream video using a network media player that another person has suggested to you. If my memory is correct, I believe the result was not very…
I have various digital video files on my computer in my office at home. I would like to watch them on my television in another room. I would also like to be able to pause, fast forward, etc the digital video when I am watching it.
I have a Dell computer running Windows XP (not the media edition) and a cable modem.
I was planning on purchasing a wireless router and a media hub that is capable of playing back video (some media hub products only handle photos or audio). The new Linksys product looks promising ( WMCE54AG see:
), but it requires a Media Center PC.
Would a Tivo product help me with this?
Is there a media hub solution that would work with my PC?
What am I missing here?
Thanks.
Rick
Give this a look, I havent tried it but it sounds pretty neat
Maybe this would be of interest -
You may want to post your message in rec.video.desktop newsgroup. There was one person in that newsgroup who had tried using wireless connection to stream video using a network media player that another person has suggested to you.
If my memory is correct, I believe the result was not very encouraging
-- something to do with the network media player has too little buffer and the wireless connection is too easy degraded by people moving around, cordless phone, microwave, and such, and the software in the network media player is too buggy.
Seem like using wireless to stream video is close to bleeding edge at this point -- there probably requires a lot of adjustment and trials and errors to get this to work OK. I don't have that kind of time; therefore, I decide to wire most of my house with GigaBit wired connection for streaming video. Areas in my house that I have a hard time to run cable (such as in a second floor of my house that doesn't have an attic), I will use wireless -- but only for sharing internet connection and is not for streaming video.
I actually have a Belkin pre-N wireless router that I may try to see if I can use it to stream video. But I am not keeping my hope high, and I cannot do this test until Belkin comes out with a PCI version of their pre-N wireless adapter (they only have a PCMCIA version for laptop).
My suggestion is to run cable between your office and your TV room and be done with this. There is a very easy to setup home-network-model shown in LANshack.com web site; that version allows people to construct home network using ready made cables.
Hope this helps.
Jay Chan
Jay -
I just picked up new pre-N Belkin equipment yesterday. Took me visits
to three different stores (2 different CompUSA's and one Circuit City),
but I wound up with the router (F5D8230-4), a PCMCIA card and the PCI
card. Although Belkin doesn't list it on the website, it's out there in
the stores (some of them at least). The way Belkin packages the PCI
card, it's actually the PCMCIA laptop card packaged with a
Cardbus/PCMCIA adapter. You install the adapter first, reboot your
machine and Windows (XP in my case) recognizes the adapter as a Ricoh
cardbus adapter and instantly installs it. Then you run the Belkin
install program, and it prompts you to insert the card so it can
install the driver into Windows.
I was concerned that there was no provision for an external antenna,
since the card wound up on the back of my wireless pc, BEHIND the pc,
facing AWAY from the new Belkin router (which is about 40 ft away,
through a couple of rooms and lots of furniture and glass. In my
previous setup with DLink super g, I had to install a 6 dBi external
directional antenna on the dlink dwl-g520 PCI card, and a 6 dBi omni
antenna on the di-624 router to get a good signal in this remote
location - hence the concern.
However it turns out that the Belkin pre-N signal is SO much better
that there's no need whatsoever for extra antennas. With the tiny
PCMCIA card poking out of the back of the pc, sitting in its adapter,
I've been getting a consistent 97% signal, and incredible speed,
stability and throughput.
Considering that you should see at LEAST something like 45 mbps true
throughput (probably more - I haven't tested yet), I think you should
be able to stream video. You also have the option to set QoS option
(quality of service) in the router to give preference to video streams
and VoIP if you use them on your WLAN.
FWIW I can happily stream a DIVX movie across an 802.11g network, via a wireless router, and play it in real time. At 700MB in, say 90 minutes, that's 7.8 MB per minute or ~1Mbps - not much of a challenge over a 54Mbps network.
I do run into stuttering problems doing the same thing between an 802.11g laptop and an 802.11b laptop via the router. Maybe that's because the
802.11b laptop has only a PII 300 processor.
I tried to access a film on a shared DVD drive across the network but couldn't get it to display the menu, never mind play the film. I was probably doing something wrong though. I tried WMP 10 and Power DVD 5.
Glad to hear that you find a way to use their Pre-N wireless adapter in a PCI slot. Last time when I went to the local CompUSA, all I see if their adapter in PCMCIA format. May be I was not looking hard enough.
I am happy for you. Seem like this is a great product for people who don't need to worry about whether this is 'N' or 'Pre-N' (such as in a home network where there is only one wireless format).
Unfortunately, I will need to return mine today, and exchange it with a dual-band A+G wireless router. My pre-N wireless router is busted. One week ago, I changed some settings through their internal menu. Since then, it has stopped working. Even worse is that the reset button at the bottom of the router doesn't work. That why I said "I am not keeping my hope high" in my last message. Adding insult to injury, a week ago the tech support told me that they would send me a replacement unit. Now, they tell me that they don't have a record of this conversation. I wait one week for nothing. I get enough of this.
You may want to make sure the reset button in your pre-N works before the refund period runs out; otherwise, you may experiment with changing some settings in the router, and it may stop working and you cannot reset it. If their tech support promises you a replacement unit, you need to call them up everyday to check the status to make sure that they don't lose the record.
Hope you have a better luck than mine.
Jay Chan
Great to hear this. Although I plan to wire most of the house, I cannot wire to two rooms in the second floor. I will try something like a dual-band A+G wireless router in order to stream video and share internet from my second floor master bedroom to those two rooms.
The "DivX" thing seems to be a good idea. But the TV-video capturing card (Hauppauge PVR-250) that I use cannot capture video directly into DivX. I will have to do one more step to convert the video from MPEG into DivX. I think I will pass on this one. I will wait until I find a TV-video capturing card that supports DivX natively. Meanwhile, I will have to capture video in low quality (such as VCD format) in order to avoid taxing the bandwidth.
I am under the impression that your 802.11g will downgrade to 802.11b performance level if you mix 802.11g with 802.11b. This probably explains the reason why the performance is not good when you introduce the 802.11b laptop into the mix. You may want to borrow a 802.11g adapter for your second laptop to see if this helps.
Of course your PII 300MHz CPU can also be the source of the problem. I am under the impression that the CPU needs to decode the DivX video, and I am also under the impression that we need something like a
800MHz CPU to be fast enough for decoding video. Obviously, faster CPU will give you a better performance in this case. I am in a similar situation that I also have a low performance PC (as a client). I plan to add a Sigma Xcard to use hardware to decode MPEG (and DivX). Unfortunately, this solution will not work in a laptop because a laptop doesn't have enough space for an expansion card.
Hope you will be able to solve this problem soon.
I am not sure. Is this a copy-protection "thing" that the DVD drive manufacturer doesn't want people to share a DVD movie over the network. Have you tried sharing your own home video on a DVD instead of a copyrighted movie on a DVD? Anyway, this is WAY beyond me. You may need to ask this in the rec.video newsgroup.
Jay Chan
