Netflix classic Dr who
Jul 28, 2014 4 Replies
Jump to replies (4)
Netflix classic Dr who open original image
Search "classic" and classic Dr Who comes up. Almost all the original episodes from the 60's,
70's, and 80's you missed and always wanted to see. Now you can.
If you use VPN and access Netflix on a UK server you can get a lot of newer movies the US Netflix wont get for a long time. The selection of older movies is also better.
How doe one go about setting that up?
You have to locate a company that has VPN servers that will terminate somewhere in the UK.
You can use commercial companies like "Private Internet Access" found at
? or choose one of the many free services that show up when you do a Google search for "us to uk vpn free".
The VPN tunnel goes from your local PC to a server that the VPN tunnel company controls. They in turn will continue the tunnel to a server they have in the country you want to troll around in such as the UK.
You have to pick and choose to find a VPN provider, free or paid, that has access from your local country and has servers in the country you want to access.
On my list is to get one of those free (OK, trial) Amazon cloud accounts. There are instruction on the internet how to use it as a VPN in additional to whatever else you want to do with it. Amazon can handle multiple countries.
This is just some random hit on how to set one up.
It may not be the best example.
