Looking to Buy an Orinoco Wireless for Linux Fedora
Nov 27, 2004 1 Replies
Hello,
I have Fedora 3 and a laptop, looking to purchase a Orinoco Classic Gold wireless card model 8410-WD, thought I'd see if anyone has had success or failure in using this card for Linux or Fedora Core3?
I am looking to use the card in Promiscuous mode with Ethereal. My Linksys card just doesn't cut it...
Thanks!!
Tory
Hi Tory,
i know, its not the answer u want... I believe its no problem to get an orinoco run, there are many howto's about it!
It's a mess, I never tried to scan with fedora. But the card was ready to use for normal operations without complications...
And on SuSE there wasn't a great problem to scan... on knoppix I could use kismet, ethereal and other things without any problem with that orinoco card...
But I think, soon somebody is giving u the REAL answer u want;)
But until that, don't worry it maybe would not be possible to make this card work for your use.
regards,
Jens
Tory Brown wrote:
