Using Ethereal for Sniffing Wireless but No Packets on WindowsXP
Nov 26, 2004 3 Replies
Jump to replies (3)
Hello,
I have a laptop set up with Windows XP, the wireless card I have won't work with Linux, and I am using Netstumbler to find wireless access points adn doing some wardriving, while running Ethereal I don't get any packets on any of the access points I pick up as active. I was reading a paper that stated that if you use Windows to attempt to sniff wireless that you would only get local packets and not any other traffic but if you use *nix that you can get packets all the way back to the other router.
Is there anyone that has been able to do any Wardriving, using WindowsXP and been able to sniff any packets successfully?? If so, how?
I know I could just go buy a diferent card that would work with Linux, but I can't do that right now but I am giving it serious thought but all-in-all I'd like to get this solution to work....sot of an obsession now.....
Thanks!!
Tory
Hello Tory,
I just took a short look to
Maybe you Did not install WinPcap?
Can you test this at some own network? I would try to get an internet connection about wireless lan, sniffing. So you should see some packets coming in. I just tried under linux using ethereal. But I can imagine, that there is something with your driver. Did it supports the promiscious-mode? In this mode your network adapter will also get packets which are not adressed to it.
I used Netstumbler a short time...until I got my orinoc classic gold card. In my opinion a real good card and the possibility to adapt a antenna is real nice - especially for driving arround in a car...
May I ask in which country you are wardriving? I hadn't to much time to do it by myself and I am interested about that in other countries.
Only in the few big cities there is a real scene in Germany...
regards,
Jens
The vendor-provided drivers for Windows XP do not support promiscuous mode. The wifi adapter looks like a virtual Ethernet to your XP's TCP/IP stack. Ethereal can intercept traffic to/from your wifi adapter as pseudo-Ethernet frames, but it cannot see any other traffic.
Linux has drivers that support full promiscuous mode, so it does not have this limitation. There are proprietary drivers for Windows that support promiscuous mode, but they are generally available only in commercial wifi analyzer packages that cost many hundreds of dollars.
I have heard of pe>> Hello,
That is what I was afraid of, I guess it is time to somehow get a Orinono and plug in an antenna.
Thaks for the response!!
Tory
