Looking for Netgear DG834G Wireless Router Kit Bundles [UK]
Jan 04, 2005 7 Replies
Jump to replies (7)
Looking for Netgear DG834G Wireless Router Kit Bundles [UK] open original image
I'm trying to find the cheapest bundles for the Netgear DG834G v2 Wireless Router in the UK. Has anyone seen any really good bargains on this product?
Thanks
pcworld were doing the router for £44.99, not sure if that's still the case.
Bal
I recommed the BELKIN WIRELESS PRE-N MIMO ROUTER 8x Greater coverage than
802.11g 6x Greater speeds than 802.11g. £103 PC World
£61.27 (£71.99 inc VAT) at
Graham
Tis not hackable like the Linksys one:
How do you get 8x 'greater' coverage when the output is by law limited to
100mW, same as any other wifi ? Does it come with 24" parabolic dish ? Regards, Martin
I have one of these and can highly recommend it. I also got a WGE101 wireless bridge. However, be warned Netgear support is atrocious. They WGE developed a fault and they have had it since November on a "by return" swap out. No amount of pleading , phoning or emailing will get them to tell me what is happending. Actually that is not true, they make up a different excuse every time!
