Linksys WRT54GL - assign static IP to MAC address?
Aug 04, 2006 5 Replies
Duane Arnold
'll assume you know that static IP(s) are those IP(s) that cannot be issued by the DHCP server on the router. If the DHCP Issue Count is 10, then IP(s) 192.168.1.100 through 192.168.1.110 are the DHCP IP(s). 192.168.1.111 to 254 are static IP(s), along with 192.168.1.2 to…
Linksys WRT54GL - assign static IP to MAC address? open original image
So I just replaced my Netgear router with a Linksys WRT54GL at home. In netgear there is an address reservation function in which you can assign a static IP to each computer using their MAC addresses. Can you do that with WRT54GL? I have browsed through the admin interface and can't find any. If not, is there any 3rd party firmware that does that? I want to have static ip for each computer for port forwarding purpose.
My WRT54GL has the linksys firmware version 4.30.2. Thanks in advance.
I'll assume you know that static IP(s) are those IP(s) that cannot be issued by the DHCP server on the router.
192.168.1.110 are the DHCP IP(s). 192.168.1.111 to 254 are static IP(s), along with 192.168.1.2 to 192.168.1.99.
Duane :)
YOu're correct. The stock Linksys firmware does not support "static DHCP", "reserved DHCP", "reserved leases", "Pre-assigned DHCP", or whatever it's called this week.
DD-WRT and the other alternative firmware such as OpenWRT all support static DHCP.
DD-WRT:
their wiki SQL server recovers from an apparent trashout).
OpenWRT:
On Fri, 04 Aug 2006 22:57:24 GMT Duane Arnold wrote: | snipped-for-privacy@hotmail.com wrote: |> So I just replaced my Netgear router with a Linksys WRT54GL at home. |> In netgear there is an address reservation function in which you can |> assign a static IP to each computer using their MAC addresses. Can you |> do that with WRT54GL? I have browsed through the admin interface and |> can't find any. If not, is there any 3rd party firmware that does |> that? I want to have static ip for each computer for port forwarding |> purpose. |> |> My WRT54GL has the linksys firmware version 4.30.2. Thanks in advance. |> | |
| | I'll assume you know that static IP(s) are those IP(s) that cannot be | issued by the DHCP server on the router. | | If the DHCP Issue Count is 10, then IP(s) 192.168.1.100 through | 192.168.1.110 are the DHCP IP(s). 192.168.1.111 to 254 are static IP(s), | along with 192.168.1.2 to 192.168.1.99.
192.168.1.100 .. 1 192.168.1.101 .. 2 192.168.1.102 .. 3 192.168.1.103 .. 4 192.168.1.104 .. 5 192.168.1.105 .. 6 192.168.1.106 .. 7 192.168.1.107 .. 8 192.168.1.108 .. 9 192.168.1.109 .. 10 192.168.1.110 .. 11
snipped-for-privacy@ipal.net hath wroth:
[Q] How can you recognize a programmer in a crowd? [A] Ask everyone to count to ten. The programmer will start with zero. Everyone else will start with one. [Q] How many fingers on both hands? [A] Eleven. Counting from the little finger, it's 10 - 9 - 8 - 7 - 6 and 5 more makes 11.
On Tue, 08 Aug 2006 08:36:20 -0700, Jeff Liebermann wrote in :
Actually: ... and 5 less makes 1. Oops.
