Internet Connection dropping
Feb 11, 2007 1 Replies
Hello,
I am using a Linksys WRT54G router with a laptop computer and a Comcast internet connection. The connection drops about every 20 minutes or so. From reading the forum at Linksys' website, many people are having this same problem with no apparent resolution. Does anyone have any idea how to fix this or should I return the router and pick something that actually works? Any suggestions?
Thanks.
On Sat, 10 Feb 2007 20:07:44 -0500, Circe wrote in :
What firmware? The latest? What does "drops" mean? Windows XP loses connection? Router locks up?
Try DD-WRT firmware if you have a supported version of the Linksys router. Otherwise return it and get a Buffalo (which is supported by DD-WRT).
