I have a LinkSys Wireless G Broadband Router with SpeedBooster, WRT54GS, FIrmware version 4.70.6. I have a machine whose MAC address I know and I want to always assign that machine the local IP
192.168.1.104. How do I do that?
Thanks, - Dave
I don't know about that Linksys device specifically, but usually you would do what you want on the machine itself. There are various ways to achieve this. Google for "assign a fixed ip address"
Read the full replyHi,
Thanks, - Dave
snipped-for-privacy@zipmail.com hath wroth:
You don't. The stock Linksys firmware for the WRT54GS does not have a "static DHCP", "static lease", "pre assigned DHCP", or whatever feature. If you need this feature, I suggest you install an alternative firmware, such as DD-WRT, which does have this feature:
snipped-for-privacy@comix.santa-cruz.ca.us (Jeff Liebermann) wrote in news: snipped-for-privacy@4ax.com:
Why so complicated?
A static IP address for the PC is assigned in Windows' own network config. In Network -> Properties -> TCP/IP Properties, just set "Use the following IP address" and be done with it. The DHCP server and client don't enter into the picture at all.
All the machines on my home network have static IP addresses so I always know which machine is generating what traffic.
Netgear offers an option to fix a particular MAC address to a particular IP address, but that option doesn't seem to be present in the Linksys routers.
The default DHCP range is 50 addresses. You could assign that machine a static IP address that it beyond 50, but still within the subnet of the current routing.
Bert Hyman hath wroth:
Easy.
That's fine for all your home machines, which don't go anywhere. If your router had a "static lease" feature, you could just assign the IP's in the router, and leave the computahs set to DHCP.
Incidentally, I used to use Netswitcher to juggle IP's because many of my customers were using static IP's on their network.
Is this machine mobile? Can you set a static address? Can you set an alternate ip address?
That's not the way I read it, since all he said was:
"I have a machine whose MAC address I know and I want to always assign that machine the local IP 192.168.1.104. How do I do that?"
But, if that's what he meant, never mind.
Well, I can see how you read it to mean something like how do I configure the PC to always have the same IP address. However, in the previous sentence, he also disclosed that he has: I have a LinkSys Wireless G Broadband Router with SpeedBooster, WRT54GS, FIrmware version 4.70.6. which I read to mean that he wants to know how to configure the wireless router, and not the PC, for a static lease. I'll stand on my interpretation (and my answer).
