Has anyone tried the locater? If you have, how good is it? I think the one I bought is defective.
Hawking WI-FI Locater Info
Mar 25, 2005
Haven't used the Hawking but have used the kensington. similar setup but the Hawking looks a lot slicker with the flip open antenna. My main issue with these devices is that only tell the strength of the signal, nothing else. The one I use now
tells you whether the network is open, the name of the network, the strength & the channel. I like to know if I have somewhat of a chance to access before I boot up my laptop. So far its worked great though it is a battery hog.
The one I had was defective, Compusa exchanged it for one that works fine. Now I get 5 bars at my desk.
Teddybare
