Download via wireless
Apr 19, 2006 41 Replies
I'm assuming, by "download", you mean from the internet and not local file transfers.
If your wireless pipe is bigger than your internet pipe, then there /should/ be no difference between downloading over a wired connection versus over-the-air.
I.e., Roadrunner gives me 5 Mbps downstream, which both my 802.11a and
802.11g handle just fine. I see absolutely no difference downloading over-the-air than I do directly wired. On a good day, even 802.11b works just as well. 802.11b (11 Mbps) is cutting it close to carry 5 Mbps though. You never get the advertised speeds. Hence, "on a good day".
Now, local file transfers -- thats different. Good ol' CAT5 still comes out ahead. 802.11g (and 802.11a) give you mid to high 20'ish Mbps, which isn't bad, but can be a little painful to transfer huge amounts of data around such as doing Ghost backups.
BTW: If you are using Windows, before even start looking at wireless, the first thing you want to do is open your RWIN size. Its a value stored in your registry as TcpWindowSize. By default, Windows has you bottlenecked. Value you want to use is your (advertised internet speed x average latency) divided by eight...
Google/deja for more on it..
Have fun...
No John, I *know* along with tens of thousands of others.
Tell you what, send an email to ask the MSDN subscriber downloads support team what other protocols are supported and stop arguing something for the sake of it again.
David.
