I tried to get hold of you for quite some time today via the phone...I needed...
A
Adair Witner
I think the obvious answer would be yes. I'd reccomend buying a cup of coffee or reading a book as it's going to take awhile anyway.
Adair
D
Doug Simar
Most hotspot operators will limit your downstream bandwidth anyway to keep bandwidth hogs under control. If your going to pull that kinda size file it might be better to go to a friends house that have cable/DSL and use their bandwidth. It might be faster than a hotspot.
Doug
M
me here
I also have dial up and use the public library to download large files via wireless laptop occasionally.
There is usually a download limit for a set period (eg week or month).
They dont like large downloads as it reduces the speed of other users online, howeverI've gone up to 200 meg without complaint.
You could use a download manager and do it in stages (ie. part download and then resume later) to spread it over several days.
The speed in our library is usually pretty good - about max for 54g wifi.
Cheers
Rob
D
dold
I used the Real.com download manager to download ISO images via dialup. It would take days, poking along in the background while I was doing other things, but it would eventually finish.
Real.com doesn't offer that manager any more.
a current free product from Sun.
M
me here
Hi Clarence,
I was thinking more along the lines of spreading out the download over several days when using the library net so they wouldn't get upset.
But you could do it via dialup I suppose - take a long time though :-)
Either way, it should work.
Cheers
Rob
J
John Navas
On 29 Apr 2007 10:23:25 +0950, "me here" wrote in :
That's not a good standard. What you are apparently doing is inappropriate and rude to other patrons.
What you should be (and apparently aren't) doing is throttling your speed sufficiently so as to avoid degradation of service to other patrons, taking no more than your fair share.
Probably only because most patrons aren't doing what you are doing.
Free public Wi-Fi is a classic case of Tragedy of the Commons. Eventually it gets (ab)used to the point that service becomes poor, and sophisticated and draconian measures become necessary.
I know of a public library that was being so abused by illicit filesharing that the free Internet access was completely shut down.
Report Content
ASAP.
