problems in connecting to Limewire
Jul 21, 2007 1 Replies
I used to connet to Limewire just fine (don't worry I'd only use it for programs that I'd missed that has been on TV). Now that I've moved onto a wireless network the connection is terrible, no files are found and nothing downloads. I can connect to the Internet without problem and download files (like drivers or updates), so there is a connection.
I'm using a Belkin router (which I installed successfully)but I use a Linksys network adaptor (which I had to download the drivers for as it didn't come with an installation disk) - I thought this might be the route of the problem, but how can I connect to the internet withou problems if they are not compatible?
does anybody have any ideas??
Peter
I'm guessing, but my client sofware ZD, was crap. I don't use it to connect, but use XP connection software instead. You might try that.
