Desktop Card/Antenna to catch neighborhood wireless?
Dec 06, 2006 16 Replies
NetSteady
Waterboy, I sell the Signal Seeker and I've seen it shoot over 2 miles. Chris - - - - - - - - - - - - - - - - - - - - Christopher M. Hutchison, CEO NetSteady Communications, Ltd. Phone: 614-255-5575 Mobile: 614-853-0091 Skype: wifi_chris
hi,
i want to put a desktop computer upstairs, and see if i can piggy back onto nieghborhood wireless
so, i guess i need the "Longest Range"
is there a "best" card antenna to accomplish this? ...or what should i look for?
thanks waterboy
On 6 Dec 2006 10:36:55 -0800, snipped-for-privacy@financier.com wrote in :
Hawking HWU8DD Hi-Gain USB Wireless-G Dish Adapter
Waterboy,
Chris
What would you need if you want to feed the acquired signal into an access point for your own secure network?
On 6 Dec 2006 15:00:48 -0800, "Bucky" wrote in :
Wireless Ethernet (client) bridge with external antenna capability cabled to wireless access point with different SSID and channel; e.g., Buffalo WLI-TX4-G54HP (with WLE-DA2 antenna) and WHR-G54S.
On Wed, 06 Dec 2006 23:09:34 GMT, John Navas wrote in :
Depending on signal:
  • Buffalo WLE-AT-DACW might be a viable alternative to WLE-DA2.
  • Buffalo WLE-HG-DYG would provide more range than WLE-DA2.
Not much real information about the product on that site.
"NotMe" hath wroth:
Search Google Groups for "Signal Seeker" or "Ed Williams".
I never could get much in the way of specs out of Ed. However, he did once leak an FCC ID of the device as FCC ID:NHPWLB1500. See below for what details I could extract.
That was about 18 months ago, so things may have changed.
Given this scenario, say we had made arrangements to share his connection while he was gone to work or whatever. Would this bridge/repeater or Ethernet converter allow me to capture his wireless connection and then add it to my hardwired network running along side of my DSL. In other words, can I feed both connections through my router to my networked computers?
On Fri, 8 Dec 2006 08:23:06 -0700, "peterf" wrote in :
His? This thread is about open neighborhood wireless, not stealing service from a neighbor.
Both won't work at the same time without special hardware.
Stealing! In our situation, 3 of us in a sort of triangle all have wireless setups. Say we all wanted to bridge our connections and then buy a lower speed plan and then share the cost. It could cost us all a few dollars per month and the unused bandwidth would route to the house that needs it at the time. The one neighbor for example is got sold a much faster connection that he needs for e-mail and surfing. Say I wanted to give him oh, $5 per month to use part of his bandwidth during the day when he's at work. It would still be lees for me than an upgrade to my DSL, lower his cost and everything work out for the best. My question is not an ethical one but a technical one. What kind of "special" hardware are you referring to?
On Fri, 8 Dec 2006 09:29:38 -0700, "peterf" wrote in :
Load balancing over multiple connections is relatively easy (assuming high enough wireless link speed to handle all the traffic); bonding of multiple connections isn't. Google PPP (Point-to-Point Protocol) MultiLink/RFC 1990. With load-balancing, only certain applications with multiple connections will show an increase in throughput over a single link; e.g., FTP download accelerators, peer-to-peer filesharing.
I put one on ebay, with tech specs:
Chris
On 8 Dec 2006 12:42:04 -0800, "NetSteady" wrote in :
No ads here please.
