Dead PCMCIA slot?
Oct 30, 2007 5 Replies
Mark McIntyre
What OS are you running? Does it actually support PCMCIA? Windows NT doesn't for example.
When I insert my wireless card, NO lights come on. Not a power light, nothing. Does this indicate the slot is bad? I've tried a second card and get the same results.
-Pete
I'm running XP Pro. Once upon a time it all worked. There aren't even power lights on the card(s) when I plug them in to try.
Go to control panel system and make sure that the driver is installed.
Pete wrote:
Pete hath wroth:
Let's pretend you walk into an automobile repair shop with roughly the same complaint. What the very first question the service tech will ask?
Answer: What model laptop? What maker and model wireless card?
Many laptops include hardware diagnostic software. Once you disclose the maker and model number, such tools can be found. You might want to try a non-wireless PCMCIA device, such as a PCMCIA to CF (compact flash) memory card adapter. They cost about $10 and are rather handy for testing PCMCIA slots.
Incidentally, the most common problem I've seen with allegedly dead PCMCIA slots are mashed pins on the connector inside the laptop. A visual inspection should show if that's a problem.
I had done that but didn't realize the big X was for the card. I did a "reinstall driver" from the directory (I downloaded the software) with the drivers, etc., and it works -for the moment. Thanks.
-Pete
