D-Link DI-624
Jan 12, 2005 1 Replies
Can I use this as just NIC. I already have a router on network can I change the settings on this to join the other network. Thanks Ed
if your other router includes a dhcp and nameserver forwarding (as normally routers do) then i dont see why it wouldnt work. maybe one thing to check is that your d-link-lan has a different ip-range then the 1st router-lan.
gl
