Vonage Ala stick! The rumor has it .....
Jun 20, 2006 0 Replies
As posted on broadbandreports
Looks like Vonage is going to come out with a mobile USB stick that will plug into a USB port giving the user a soft phone to dial out on. They currently have a downloadable softphone that you can only get as an add on and it is not unlimited and uses a different number.It is also an extra $9.95 per month. The stick is a great idea if you are using a computer that is not yours, and you can't or won't download to it.
The plan as I heard it is they will make claim to being the first mobile phone on a stick. (hmmm...what about voicestick ?)
The real question will be is if it will allow usage with ones existing Vonage phone number and call plan or if it will be just an add on to the current add on plan limited to 500 minutes, at a current separate charge of $9.95 per month.
Vonage needs to be careful, as they seem to not be hitting the market correctly as of late.
