UMTS Gateway - HG-5000 Series
Aug 27, 2005 0 Replies
UMTS Gateway - HG-5000 Series open original image
Hypermedia Systems announces the launch of its new UMTS Gateway - HG-5000 Series.
The UMTS Gateway is designed to utilize the more favorable rates on calls from UMTS network to other networks (aka UMTS Router, Fixed UMTS Terminal, Fixed Wireless Terminal). The result is that by using 3G Gateways the savings on calls form the UMTS Gateway will be in many cases higher in comparison with calls from the existing GSM gateway. The UMTS Gateway integrates Motorola 3G mobile phones - C975 & E1000 with any additional accessories such as power adaptor and data cables.
Main Features:
  • From 12 to 36 3G ports
  • Integrated Motorola 3G mobile phones C975 & E1000
  • Embedded VoIP (H.323)
  • No need for any external VoIP GW(Cisco, Qunintum and others)
  • Up to two PRI interfaces
  • Advanced LCR & routing groups
  • IP address & DDI pattern restrictions
  • Integrated antenna splitter
  • WEB management and control
  • High quality of voice
  • Inbound and outbound calls
  • Redundant power supply
  • Fast and easy installation
For more information on this company:
