Draytek VoIP DSL Router, Vigor2500V model.
Nov 24, 2004 0 Replies
Draytek VoIP DSL Router, Vigor2500V model. open original image
The DrayTek Vigor 2500V is an ADSL firewall/router - ideal for sharing your ADSL connection between several PCs, with a built-in VoIP (Voice over IP) telephone port. The phone port enables you to use your existing ADSL broadband connection to make VoIP calls to any other compatible device, anywhere in the world and anywhere on the Internet, free of charge. You can receive calls too of course, and all with a standard (analogue) telephone which you connect into the socket on the back of the router. By using the DrayTEL PSTN gateway (see later) you can also make calls to any regular phone line too, including mobiles, as well as receive calls from anyone - the call is carried to your phone via your internet connection so your regular phone line remains free for other people/calls.
Having the Vigor2500V on your ADSL line effectively gives you an extra phone line - with no extra line rental, so when family or co-workers are tying up the main line you can still make calls using the phone on your Vigor2500V - ideal for teleworkers who need that extra flexibility. The Vigor2500V is visually pleasing too; its curved lines and brushed silver finish enable it to fit into any environement stylishly.
