Similar functionality to SkypeIn
Aug 13, 2005 5 Replies
Jump to replies (5)
I have just been looking at SkypeIn
. It sounds great, but I want to have a regular telephone number in Australia so friends can call me here in Germany for the cost of a local call. Unfortunately Australia is not one of the countries listed for the SkypeIn service. Is there any other technology available at the moment that will let me do this?
Thanks in advance.
Easy. Set up two accounts with Sipgate.de, give one number and setup details to your friends in Oz, and they can call you for FREE on the other German No. You can use free soft phones like Xten Lite or, if you have router, plug ATA and ordinary phone into it. Better still get VoIP equipped router e.g. Draytek 2600V, Zyxel
2602HWL, ZoomX5V or AVM Fritz!box. Regards, Martin
Thanks for the info Martin. If I just want a telephone number in Australia that allows people to call it, without any setup on their behalf, could you suggest anything?
Cheers
that in Australia OZtell sells DiD's for "$1.95 per month. (IAX2/SIP trunk required at at additional $1.95 per month)", and at
it lists also "Conexim Australia - Australian provider of business voip VAR solutions - Sydney/Melbourne DIDs, outsourced IVR hosting, fax to email and unified messaging services".
Enzo
Lispo:
You need to investigate Oz VoIP providers, I haven't got a clue. VoIP providers will often not provide local numbers to foreigners, so you may need someone down under to do that for you. Regards, Martin
For what it's worth, I've been using an AVM Fritz!Box Fon for the last few weeks and it's been excellent, I can't fault it for performance. The manuals could do with a little work, the setup wasn't as easy as it could have been, but once I figured out what info needed to go where it hasn't missed a beat and the call quality on my Sipgate lines is perfect.
Ivor
