I need a high quality pc -> pc connection
Jun 14, 2005 1 Replies
Hi all. I need a pc -> pc (over internet) connection, such as icq, msn, skype... I'm using skype, it runs very good... but I transfer not only voice but also music, and I'd need more bandwidth. I dream a program that:
- it could use a larger bandwidth than skype
- it could switch off any "automatic level control" to have the more dynamics I can...
Is there something? I appreciate any suggestion.
Thanks a lot.
If your using DSL routers at either end you could setup a point to point IPSec tunnel between the two routers. The Linksys WAG54G supports upto 5 tunnels.
Once the tunnel is setup between the routers you ought to be able to enable windows filesharing.
I haven't tried this myself though.
