CLID problem
Mar 17, 2005 1 Replies
Hello,
I have a Cisco AS5300 with 12.2(15)T14 IOS version onboard and two e1 interfaces connected to PSTN.
I would like to send CLID in an outgoing ISDN calls. I am using SIP to call Cisco. Unfortunately i always get the following debug message and no CLID on pstn side: EVENTd: pak_private_number: Calling Number IE is being stripped EVENTd: pak_private_number: Packing Calling Pty. Num. without digits SERROR: pak_private_number: didn't copy oct3a reason: not CALLER_NUMBER_IE EVENTd: pak_public_number: Calling Number IE is being stripped.
What is more the outgoing call sends the base number of my number range.
Could You please give me an advice how to get out of that.
Thanks, Mac
I've had success on a 5350 with PRI, but never with T1. I presume E1
would be similar to T1 (but you have more channels :-). If I do not
pass E.164 number through, my provider tags the call with the span ID
(lowest number configured as you pointed out).
Send me a private note if you want to try some further testing.
JDB
