Call Forward When Busy
Aug 30, 2004 2 Replies
I am thinking of getting some Sipura SPA-3000 VOIP adapters to connect my remote offices together. I want to put two of these units at my main office, so that I have enough lines for the incoming traffic.
My question: If I have an incoming VOIP call to one of the units, which is busy, is there any way to automatically have the call forwarded to the second Sipura unit?
Thanks,
Hello,
Definitely possible if you use some smart SIP server, e.g. PortaSwitch
). It has "follow-me" feature, so you can manage a list of numbers for forward the call to if your SIP phone is busy, not answering, offline, ...
WBR, Andrew
The down side of SIP as you will need a SIP proxy to do a lot of feaures like that. For a simple solution maybe look at H323 devices such as
where most have roller over feature where you can send it to another unit if that one is busy and you dont have to worry bout the SIP proxy.
Cheers
