Re: Replacement for Siemens Gigaset
Nov 06, 2005 0 Replies
I've been mostly satisfied with the first two generations of the 900MHz EnGenius system. It supports handset-to-handset calls but not conference.
I've been thinking about my "next generation" cordless phone. It occurs to me that it might be possible to leverage my existing 802.11 access point infrastructure to support 802.11 VoIP handsets with a gateway like the Sipura SPA-3000 to a POTS line. (Obviously it could make other kinds of VoIP calls as well.) Has anybody tried to build a cordless phone this way?
In reading the SPA-3000 configuration guide I think I noticed a possible problem. It appeared (and I should say that I spent very little time on this so I may have missed something) that the gateway will not forward a POTS call to VoIP unless it actually answers the call. I noticed that you can control an answer delay in order to accommodate other devices on the POTS line, but that's not quite what I want. Is there some way to send a setup message to the VoIP handset on detecting a ringing POTS line but not answer the POTS call unless the VoIP handset is itself answered?
Dan Lanciani ddl@danlan.*com
