POTS line signal to PC MIC-in jack circuit?
Nov 09, 2005 3 Replies
Carl Navarro
How about the USB port? Try . The two port unit retails for just under $250 and the 4-port just under $300. You supply the computer and they record it in their format, but you can convert it to an MP3 file for e-mailing. Outbound calls capture the digits dialed, inbound calls…
What's the decent, cheap, way to get both talk and listen sides of a phone call on a POTS line into the MIC-in on a PC in a non-intrusive way?
For extra credit, the ability to detect ring and Off-hook from software (somebidy elses's problem) running on the PC would be nice.
Software code to listen to the DTMF tones and spit out the digits dialed would be great.
Ideas ?
Try
. The two port unit retails for just under $250 and the 4-port just under $300. You supply the computer and they record it in their format, but you can convert it to an MP3 file for e-mailing. Outbound calls capture the digits dialed, inbound calls the CID if you have it.
Carl Navarro
For telephone line interfacing:
Ring and off-hook detection:
DTMF decoding:
There used to be a nice Wintone program for DTMF decoding at
site seems to be dead just now.. I don't know places where you could find it. I don't have copy of that software.
