On Fri, 12 Aug 2005 18:38:29 GMT, Paul W. Schleck wrote in news: snipped-for-privacy@telecom-digest.org:
Pat,
> I recall that one, or both, of these free Microsoft tools
> has an option to return your copy of Internet Explorer to
> its original factory settings:
> Microsoft Baseline Security Analyzer:
>formatting link> x
> Microsoft Anti-Spyware (Beta)
>formatting link> fault.mspx
> The second tool installs itself as a startup utility, and
> runs periodically to check for spyware, so make sure that
> that's what you want. The current versions of both of
> these tools may also require that you do Microsoft's
> confirmation that you have a licensed copy of XP, so make
> sure that you're comfortable with that, also.
> I recall you mentioning using Spybot Search and Destroy, so
> I'll assume you have run the current version already (in
> Windows "Safe Mode" and from read-only media if you want to
> be absolutely sure).
> Paul W. Schleck
> snipped-for-privacy@novia.net
>formatting link> Finger snipped-for-privacy@novia.net for PGP Public Key
I think I would be inclined to try this one: Microsoft® Windows® Malicious Software Removal Tool (KB890830) Here's a pointer to it:
Flatus
[TELECOM Digest Editor's Note: That 'malicious software removal tool was quite helpful also. Thanks for the mention of it. PAT]
