Re: Urgent Help Needed With Internet Explorer IE 6.0
Aug 14, 2005 0 Replies
TELECOM Digest Editor wrote:
>> This is an appeal to any Windows Internet Explorer person in our
>> readership who can help me:
>> Wednesday night/Thursday morning someone stuck me with a virus and the
>> end result was my Internet Explorer browser is gone.
> Which virus? Usually a description of the virus will tell you which
> files and registry settings it corrupted.
> Regards,
> Colin
> [TELECOM Digest Editor's Note: It was something to do with www.coolweb
> and 180Search as I recall. I also {...]
you what it did. Try the removal tool, or if you have already deleted files and the tool doesn't work see the registry settings to delete near the bottom of the page. IE is stuck for the 180ax 'helper object' you have probably already found and deleted ...
Regards,
Colin
