Re: Power Strips for Home Networks
Jun 20, 2005 0 Replies
I've accumulated so many devices on my home network (and some devices
> that are not network related as well) that power strips are an issue.
> Most of these devices have the big 'calculator charger' type of power
> supply that plugs directly into the AC outlet.
Yes, you are not the only one with this problem. My current solution is multiple power strips plugged into multiple outlets. However, I've also seen (sorry, can't remember where, try a web search) short extension cords for use with wall-worts and power strips. The cords get the blocks away from the strip so you can use all the available power jacks.
- David
