Re: Power Strips for Home Networks
Jun 20, 2005 0 Replies
I suspect that some of you are experiencing this or have already
> solved it. So, maybe one of you can tell me where I can find
> something to solve this problem.
> I've accumulated so many devices on my home network (and some devices
> that are not network related as well) that power strips are an issue.
> Most of these devices have the big 'calculator charger' type of power
> supply that plugs directly into the AC outlet.
> I've been looking for some type of power strip that has eight or more
> outlets that are spaced far enough apart that you can plug all of
> these things into them without overlapping each other.
Another solution is short extension cords, probably available from all electric / electronic supply places. They are heavy-duty, three-prong cords about a foot long. So the normal-sized three-prong ends fit nicely in any power strip. They're also pretty cheap.
Thanks,
David
(Remove "xx" to reply.)
