I have put in a few wireless routers but never got into the internals.
> I now have one in my home and will be adding a Range Extender.
> I possess a WRT54G, running Windows 2000 and uploaded the latest
> firmware (version 3+ dated Dec 2004 I think) from Linksys.com.
> In reading the latest PC Mag, I ran across an interesting article on
> the Satori firmware and extra options it adds.formatting link
> A few questions:
> 1. Is this the best choice of stable firmware for my WRT54G to add new
> options, perhaps increase signal power (if it really works) and tweak
> other necessary parameters for best performance/range?
> 2. Are there other firmware vendors worth looking at on linksys.org?
> Thank you,
> Patty
Patty,
Look on the bottom of your router, on the sticker that has your s/n and mac address, it should have you hardware version. (WRTG54g vx.x)
If your version is 2.2 or greater you will probably have to subscibe to sveasoft.com for $20/yr and use the Alchemy release as I have. If your version is 2.0 or lower then you should be able to load the older versions like Satori(available without subscription) or openwrt(only supports through v2.0)
The signal power increase does work, but so do better antennas
