Re: Blackboards vs. Whiteboards
Apr 03, 2005 0 Replies
Dale Farmer wrote:
>> That this has nothing to do with telecom ...
> Unless it's an electronic whiteboard.
At my last job we had one of those Smart Boards. It's a whiteboard that you don't use traditional marker on. You project the image and then pick up the tools from the tray to mark up that image.
You can then save the marked drawings. BTW, this doesn't preclude you from using it as a whiteboard. I used ours plenty of times as a true whit board without having to use those damned markers.
