[TELECOM Digest Editor's Note: Or notice, for example, the setting
> of accurate clocks via the internet. I've a program here called 'Net Time'
> which constantly polls various 'time servers' around the net. When
> you set it up, one site returns data reported to have latency of .150 ms
> and another has latency of .75 ms, etc, in other words _none _ of
> them display (on my screen) -exactly- the right time. But the
> program takes a half dozen or so of these time servers, and averages
> the latencies then makes an adjustment which is as close as one can
> get apparently, to the 'correct time'
NTP (Network Time Protocol) and the associated software is a science in itself. The round-trip latency is used in the time calculations, as is the averaging of multiple servers to find correct servers and outliers. With good hardware, microsecond to nanosecond accuracy is possible.
Koos van den Hout
Camp Wireless, wireless Internet access at campsites| Koos van den Hout
[TELECOM Digest Editor's Note: Thanks for mentioning this site. I went over earlier today and selected from the 'us.pool.ntp.org' numbers for my computer clock settings. PAT]
