Use ADT system with no monitoring company?
Apr 28, 2007 11 Replies
Frank Olson
What's the equipment manufacturer? That's do-able on some systems. We'd need more information to be able to answer that question. There are limitations you should be aware of. Most alarms with a "pager response" feature will only transmit the alarm once. There's no way for the…
I'm buying a house that has an ADT system installed. Pretty basic system, just the front, back, and basement door, plus one motion detector.
The house is a repo, so I won't be getting any codes from the previous owner.
I've Googled, and seen that an ADT system can often be reused with another monitoring company. Presumably one with better service and perhaps even better price.
But I'd like to go an even cheaper route, and have the alarm call my cell phone. Is this possible, and if so how much might an alarm company charge to set up the system to call my own cell phone?
That's do-able on some systems. We'd need more information to be able to answer that question. There are limitations you should be aware of. Most alarms with a "pager response" feature will only transmit the alarm once. There's no way for the panel to know that you actually received your page (or cell phone message). If you happen to be in an area with "iffy" coverage, you could wind up missing the call. This will be of no use to you if your house happens to be on fire...
i'd try some illegal aliens. they are cheaper. and it's not rocket science
Even though this thread has been beaten to death, here is an answer.
Yes you can "probably" get the system changed to a local... IF you can find someone to work on it. where are you by the way?
No you cannot have it call your cell and get anything meaningful from it. all you would hear is a bunch of beeps and noise. you would have to add a voice dialer as someone else mentioned. (i would give proper credit if i could figure who is who anymore. JEEZ)
There's an easy way to do that without reprogramming the alarm. Several companies make automatic voice & pager dialers that are designed to connect to an alarm system. The dialers can call from 1 to 8 telephone numbers and play one or more messages when triggered by the alarm system's "bell" (siren) output. Most of these voice dialers will also send a digital pager message. They don't send text though.
The user connects the dialer to the alarm control panel's + and - 12VDC aux power terminals and the "bell" output terminals. There is a dial pad which is used to record up to eight telephone numbers to be called in sequence. A microphone in the unit allows the user to record his own messages for different types of alarm signals (fire, burglary, panic, etc.)
The plus side of these dialers is they're inexpensive and easy to use. The down side is they're not as reliable as central station monitoring. The alarm user should decide what level of security is appropriate to his needs. If police response in his area is fast and his alarm company uses a professional central station with a good track record, 24 hour monitoring is a worthwhile investment. If he's in a remote location where services are sparse or if his alarm company can't/won't do a good job, a voice dialer may be the better choice.
When any of my DIY customers wants central monitoring I refer them to an online dealer I know. His company does a decent job (I assume so since I've never heard a bad word from anyone except their competitors).
I clients want to self-monitor, I offer one of our voice/pager dialers. The choice is the client's to make. Here's a URL to our page on voice/ pager alarm dialers.
I'm in Louisville, KY.
Since I live alone, if the alarm were to dial my cellphone when I am away from home I would consider that to be very meaningful information. Either a break in or a false, one of the two.
or a test signal, trouble, ac fail, restoral, power fail, opening, closing, etc. so if it could be forced to dump to your cell the info would not be all that meaningful to you.
Tony Sivori wrote in news: snipped-for-privacy@yahoo.com:
Too Far north from me.
But which is it? Are you going to run home every time it calls? After it falses 4 or 5 times and you start ignoring it, the next time will be real.
Ultimately it is your descision. Good luck either way
Could be, but if it is cheap enough to set up as long as false alarms aren't a problem it would be better than nothing.
Thanks, I've bookmarked the page.
If he can get it programmed to call his cell phone he can also have it only send emergency signals.
Actually, you've pretty well said it all. Anything is "better than nothing", and "nothing" is what you'll have if you're going to rely on your alarm calling your cell phone. I'd check with your local authorities as well. I doubt they'd dispatch on a call from you saying that you've just received an alarm message (unverified) on your cell phone.
