SD1+ problem
Aug 26, 2005 2 Replies
Moved into a home with an (old...) Optima XM panel with an add on SD1+ speech dialler. Problem is the dialler only dials out after an alarm when the panel is reset. The alarm condition fail to trigger it directly. Any ideas what's wrong with it? Thanks.
Sounds like the input voltage is the wrong way round. You could swap this in the panel or reprogram the unit.
To which connection in the XM is the SD1+ trigger connected.
