need help to reset 449CST wireless smoke detector
Jun 28, 2006 14 Replies
Jump to replies (14)
Mark,
Thanks for your reply. I have tried to reset the smoke detector from kaypad (*72). It failed to reset. Is there anyway to reset from the detector?
mz
Mark Leuck wrote:
The 449CST is not a wireless detector, remove power from the detector for a few seconds and it should reset.
Doug L
What is it doing? Try Code # 7 2 or Code # 7 1 I thought 449CST is a Hardwired smoke det. James
Can you be a little more vague please?
The siren will not be triggered but you should get a trouble indication or sound. It does not matter what status the alarm is showing. Fire zones are active 24 hours.
James
The system's ready status has no effect on a properly programmed fire zone. If the power is removed from a smoke detector, and a properly wired eol relay is included in the circuit, that zone will go into the trouble condition, not alarm. js
I find it kinda odd that no one has asked this guy which panel he has.....
I find it even odder that you asked why nobody asked which panel he has and you didn't ask what panel he had either
Using #72 sounded like it was an Ademco panel.
James
It sounded like a DSC panel to me.
