Low light camera (to live in basement)
Oct 02, 2007 2 Replies
Can anyone advise me here? I need a camera set up permanently in a basement, which will usually be quite dark. Sometimes a CF lamp will be on. Is there camera suited to such a placement? I found at some point some extra-low lux cameras but would like a recommendation. Must be an IP network camera.
Thanks!
Dean
network cameras do not come in as many "flavors" as regular cameras just yet. You can purchase encoders to make a traditional camera that may fit your application better to work on an IP network.
Consider using IR illumination?
