Digiplex DGP-NE96 and 306USB Direct Connect Interface - Long Run Cable to PC
Jul 23, 2005 5 Replies
Jump to replies (5)
USB extender using Cat5...up to 150 feet?
AT $100+ he'd be better off using the serial port which doesn't require any additional hardware.
A feature of the above is :- Enables main board to communicate onsite with a PC at 60m (200ft).
Connect from main board's serial port connector to PC's serial port (DB-9) or USB port.
Could someone please advise me as to what type of cable would be best to run 60m and if the connection should be serial or USB.
Thanks
