Detection Systems DS7080oP32 - need installation guide to reprogram / reset access code
Nov 12, 2012 2 Replies
Detection Systems DS7080oP32 - need installation guide to reprogram / reset access code open original PDF
I moved into a new house which has a Detection Systems DS7080iP32 already installed. I just want to be able to use the alarm system without monitoring. Does anyone know how to get the installation manual? Or how I should proceed?
Thanks
That will be tough to get unless you're willing to pay for it. Try
and ask Jim Rojas if he has it. Bosch protects their manuals pretty tightly from end-users (and non-Bosch dealers).
The user manual is here:
Keypad manual here:
If you can read Swedish, here is an idea of what you're up against (not your panel though)
One, you'll need the installer's code. Do you have it?
Two, you need to understand how alarm panel programming works. It's not so easy on a Bosch system. Yours is keypad programmable, but you need the installers's code to enter program mode and disable the dialer.
It would be easier to call a local alarm company and pay the service call to do the programming and check the system for you while they are there. I wouldn't pay anymore than $100 for that service if I were you.
PS: The backup battery probably needs to be replaced if it's older than three years. Expect to pay about $30 for it.
Thanks for the advice. I had no problem programming my last alarm system from Ademco. It seems to be more difficult to get information for this alarm system. I will try a local alarm company like you advised.
-Thanks
