Battery sealed in System?
Nov 26, 2005 2 Replies
Hi
I have an ADT system with the window monitors. One is showing "low battery." I Opened the case, but see no way to remove the AA battery. It seems to be soldered in or something. But I see no solder
Does anyone know how to remove these without damaging the components?
It's not soldered in... If you pry up gently at the positive end you should have a problem removing it.
