another entry code for LCD5500Z?
Jul 09, 2007 1 Replies
Just Looking
You need to know the master code or the partion 1 master code. Additional Codes: Up to 32 additional access codes (01 through 32) may be programmed. To program a new code: Enter [*][5][Master Code][code number 01 to 32][new access code]. The code number is a double digit from…
We are going on vacation, with a neighbour coming by daily to feed the cat. We still want to arm our home but not give the neighbour our family's access code. I assume we can program another code for them to use for the short time we are away? And then it can be cleared upon our return. I would appreciate your expertise ie how does one setup another code?
You need to know the master code or the partion 1 master code. Additional Codes: Up to 32 additional access codes (01 through 32) may be programmed. To program a new code: Enter [*][5][Master Code][code number 01 to 32][new access code]. The code number is a double digit from 01 to 32. Access codes must be four digits unless otherwise indicated by your installer. Enter digits 0 through 9 only. Press [#] to return to the Ready state. If an access code already exists for the code number you have selected, it will be replaced by the new code.
