Abacus Panel : TRBL Power
May 31, 2007 4 Replies
Jump to replies (4)
Abacus Panel : TRBL Power open original image
Does anyone know what the Error message "TRBL Power" means on an Abacus panel ? Mine has just started to go off every 10 mins or so, showing this fault message. All of the fuses are intact and there is a healthy 12v coming out of the panel. The battery is 3 years old , but also shows a healthy 12v at its output.
Any ideas ?
Cheers,Tim.
Replacing the battery would be the first recommendation.
Norm Mugford
I choose Polesoft Lockspam to fight spam, and you?
Nah fraid not...AC fail comes up as "TRBL Supply".
Sounds like a battery to me, It may have a healthy 12v of load but when needed and tested on load it will probably fail.
