20p with keyfob for garage door
Apr 24, 2007 3 Replies
Jump to replies (3)
I am using Vista-20p with a wireless reciver. The home owner wants to open and close the garage door with a keyfob. Since I am relatively new on this panel dont know how to do this. anyone can help me out
Thanks in advance Neo
You can either use the output on the keypad or the onboard relay output.
Onboard relay to close the circuit but you will need a wire from the opener to your panel. Programming can be a bit tricky but if you read carefully and take your time it usually goes smooth.
If you are using the RF keypad the should be a relay on it as well but whenever I try using the onboard zones or relay on the keypads I always get mighty confused and end up calling tech assist - then i get it working.
If he dosen't already have a keyfob. try a street smart code encryptor. much less programming.
