Using Laptop as a Monitor for Desktop Boxes
Mar 31, 2005 3 Replies
Jump to replies (3)
I was wondering if there is a way that you can hook a laptop up to a desktop box and have the video feed from the desktop box come up on your laptop screen. I have an Dell Inspiron 8500 notebook and recently aquired a cheap Compaq PII desktop to use as a file server. I really would rather not shell out money for a monitor. The ideal thing would be to somehow have the video from the dektop come into my laptop and be able to switch between viewing the desktop and the laptop on the fly. Connections that I have on my laptop are standard: USB 2.0, IEE 1394, Serial, Parallel, TV Out and VGA out. Any suggestions? Maybe I'm thinking to complicated and the ideal solution would be just to use a remote desktop situation over a LAN to get at the desktop.
Thanks
Video? No not directly. But if it's running windows 2000 server then you can just use Remote Desktop to open a session onto it. It's free with the server version of the OS. Works great. Alternatively you could use VNC but it's not as stable as RDP.
Another alternative, perhaps, would be to put them both behind a KVM switch and control them from a single keyboard, monitor and mouse. Probably not exactly ideal.
Check local thrift stores and expect to spend $5 to $15
Remote Admin Software will be the go. You did say it's a file server so it has lan. Just use VNC it's Free.
