One of my buddies wants to build a remote control mechanism to turn the volume control on his stereo. He imagines some kind of motor or servo from an RC application that is somehow linked to a pulley which connects to the volume knob with a rubber band or the like. It obviously needs to move slow and steady yet it need not move a huge distance (if geared properly). He doesn't want to use a huge RC radio to control it though. He wants something much smaller. Any ideas? He knows that there are boxes that can be added to a stereo that are essentially remote control volume devices but he is an audiophile and wants to add nothing to his system that might dirty the sound.
Stereo Automation?
Apr 28, 2011
Before remote controls and electronic volume controls were popular, I once created my own remote volume control using by using a passive photo cell connected as a variable resistor. The volume changed as the light shining on the photocell changed. I put the photocells (one for…
Before remote controls and electronic volume controls were popular, I once created my own remote volume control using by using a passive photo cell connected as a variable resistor. The volume changed as the light shining on the photocell changed. I put the photocells (one for each channel) in a small sealed box along with a small dimmable lamp and then used x-10 to remotely vary the brightness. It worked really well. Your friend may or may not think the addition of the photocell and a regular resister will dirty his sound, but I found that it did not affect the sound quality at all and I am pretty picky.
He is an "audiophile" that doesn't want to "add nothing to his system" but has a manual volume control on his stereo?
Does it use 25L6s for output?
This just sounds like a bad troll.
What the OP is asking for once was available in commercial production. A Denon integrated amp that I have has an internal motor to turn the volume knob by remote control.
Steve
Ditto. The 10 or so y/o (purchased used) Magnavox system I'm listening to right now (separate but joined boxes for the tuner, CD player, and cassette tape deck) has a remote control that causes the volume dial to physically rotate as we watch it....
Annoyingly the original remote was replaced by a "universal", so while we can adjust the volume, we can't change the radio station from our chair....
Google Internet and search eBay for "motorized potentiometer".
For example, IR control version here:
For his efforts, your friend may also get the crackles and pops and rectification that sometimes go along with a mechanical passive voltage divider.
... Marc Marc_F_Hult
