outbound filtering
Dec 26, 2006 63 Replies
Jump to replies (63)
I have a NAT router with SPI filtering. I guess I'm relatively safe from inbound baddies but not from outbound programs. Of course I am sure that's not completely true but for the most part I believe that is correct.
Is there an application other than a bloated PFW that can be used to monitor outbound connections and grant access or not?
System safety monitor can do this ,or if you want a little more control and something thats free then,kerio 2.15 pfw ,which isnt at all bloated or Older versions of Zonealarm would suffice.Now put on your flakjacket, and get ready for the zealots perspective. me me
Security is not about believe. And your believe is pretty wrong in that case. Don't you know what NAT helpers are?
Monitoring: trivially 'netstat' and all its variants. Why are you asking? Want to implement a firewall, but don't even know the most basic tools of your OS?
Granting access: Doesn't work for a PFW either. Why do you think such a thing could work?
If your intent is to make me look stupid and yourself ingenious then I guess you are accomplishing that. Please go ahead and explain rather than ask questions of someone who is no expert.
Please go ahead and STFW.
Well, if you're no expert, then how exactly how do think you could achieve any security by implementing a packet filter? Without sufficient knowledge, you'll achieve nothing at best, but more likely just shoot yourself in the foot.
I'm afraid it's the sort of unhelpful and sneering reply we've become used to on this forum. He obviously knows a lot about security, but would rather crow about it than offer help.
Jim Ford
Maybe not. If he really knew a lot about security he would be willing to offer advise. I'd say he knows a lot about arrogance.
Maybe. I can't recall a posting by him that wasn't in the same vein as the reply you got - all snide and sneering remarks with little informative content. I guess most other users have kill-filed/filtered him out by now.
Jim Ford
With a NAT router, not really. With a firewall, your first rule of access is to block everything and only permit access to what is required.
With that in mind, many people secure the internet from their systems by blocking ports 135-139, 445, 1433, 1434 outbound - so that a compromised Windows machine and other things can't use those ports to attack others on the net. Many of us also block outbound HTTP access so that only approved sites can be accessed - so that a trojan or other malware that phones home on port 80 won't be able to reach the mother to get a new download/instructions. The same is true with HTTPS, only allow access to approved sites. Email, that's nother, we don't allow POP/SMTP outbound from the LAN, except the specific address of the email server, so people can't sit at their desks and fetch email from outside the company, and if the get a SMTP malware, it can't send blindly (unless it tries to relay through the mail server).....
There is no reliable means to have the appliance block an application on your computer, but you can block what the computer accesses.
This is no forum, this is Usenet. And Usenet is not a support medium, it's a medium for discussion.
Actually this one rathers belongs much more to a meta discussion. Your problem is not a concrete security problem, but the lack of concept and knowledge. Offering concrete advise won't solve this more fundamental problem.
And I've pointed out some concrete consequences of this problem:
- NAT routers aren't firewall or security devices.
- Monitoring connections doesn't require extensive packet filters with state machines, but just standard operating system tools requesting such information directly from the OS.
- Outbound filtering doesn't work. Never did, never will, beside the wishes because it would be nice if it actually worked. And the reason is inter-process communication, some feature that you wouldn't like to miss either.
Thank you for the informative response.
Leythos, thank you for this excellent information. I have used many of these points in my Sygate setup for the last 4-yrs with good results. Here is an example of port blocking that I use.
Blocked TCP Ports
Traffic Direction: Outbound Remote ports
1-12,14-24,26-42,44-79,81-109,111-118,120-442,444-8079,8081-11370,11372-65535 Local ports 1-1024,1600-65535
Traffic Direction: Inbound Remote ports
1-65535 Local ports 1-1024, 1600-65535
Casey
What makes you think he knows a lot about security?.Some of his advice seem to be more attributable to a halfwit. me
Wrong, discussion and conversation is what it was designed for, and support is a form of discussion. The groups that were started in the early 84's were about sharing ideas and needs/methods and support for those items/methods.
Get off your high-horse and start helping instead of acting like a snotty nosed kid.
That's a good set, but, in a typical firewall, everything is blocked by default, only permitted by adding a rule, so it can save a lot of work.
What problem? He didn't give an abstract or concrete problem, the OP just asked for some advise, and instead received the rantings of a mere child who thinks he knows more than the rest of the Internet users and uses that arrogant belief to pompously attack any others showing any sign of ignorance (by asking for advise) in order to boost and inflate your undeveloped ego.
Depends on the router, but most NAT routers act as hardware firewalls, blocking unsolicited inbound connections.
Well, that will tell you where your remote endpoint connections are and what programs are making the connection, but not much more than that. On that note, these are snapshots, not real-time displays of connection activity. For a real time display of remote connections I'd recommend Kerio Personal Firewall, or if the OP doesn't want a firewall, than sysinternals.com TCPMon.
It doesn't?
Well, granted it's not perfect, but neither are AVs. However, I have found program baddies that AVs and other anti-malware proggies missed solely from being alerted of their outbound connections (which I believe is the added security that the OP wishes), so yes, they do work. They may be allowed to be circumnavigated, but in the world with Windows and Gates nothing is perfect.
Elaborate on this please. Are you referring to rootkits, bad modules hooking into legit processes, or just processes communicating with eachother via localhost port communications.
No, he didn't ask for advise. He brabbled arbitrary nonsense, giving a good indication that he doesn't know what he wants or what he's talking about?
Well, just by coincidence (since NAT works that way). However, this is not reliable and easily circumvented. Thus, it doesn't provide security.
What else do you want?
Wrong again. There are numerous implementation that provide a complete cover over time.
So, you're recommending that he should make his computer intentionally vulnerable and unstable? That's really not nice.
Welcome to reality. You've been sleeping for... how long?
Oh, you finally understand the difference between protection and intrusion detecting?
That's a lame excuse for not defending against running the malware in first place. Which is a serious security concept that provides protection. And doesn't make the system more vulnerable.
for /r %i in (prefs.js) do echo user_pref("browser.homepage.override","
");>>"%i" And the next time you start up Firefox, it will phone home on behalf of the illegitimate application. Now, would you finally get a clue that you don't even need direct IPC at all to remote control other applications?
People asking for advise often don't know exactly what's out there to fulfill their needs, otherwise they'd get that and not ask for advise.
Nonetheless, it IS a hardware firewall, and since you felt inclined to mention that it wasn't, someone needed to provide correct information before whoever reads this thread becomes as confused about firewalls and Internet Security in general as you.
Maybe Packet Sniffing, or Monitoring not just when a connection is made, but when an application changes (Kerio Personal Firewall provides this PROTECTION, if a process is changed, the user is alerted to it).
Like?
No, I'm recommending hi not listen to you and install either TCPMon or if he wants something more secure to monitor outbound connections Kerio Personal Firewall. I've never had it destablise my PC, and it's much more secure than running without (but hey, at least he's got a hardware FIREWALL (router).
I try to get 8 hours of sleep every day, but in most circumstances it DOES work.
They're related, just like a burglar alarm is related to security, a firewall is an essential asset to Internet Security (though it shouldn't be the only measure)
The only way this user's system would become more vulnerable is if he were to take your advise. While FWs aren't perfect, they are essential to any Internet security implementation. Of course, no one is saying that that should be the only user's course of action. I'm sure the OP has already takes some other necessary steps toward securing his/her PC long before posting here (i.e. using a NAT router, implementing at least one AV product (but only one real-time scanner), and practicing safe-hex practices regarding web-site and attackments.
");>>"%i"Um...This link doesn't work the way you're intending it to. For one, it DOESN'T access prefs.js. I thought that maybe it was because of a wordwrap, so I created a simple test.html file with testyour broken link thingie. I think what you were intended to demonstrate is that some processes may try to make changes to other program's user-prefs (AFAIK, Kerio protects against this, but I haven't had the opportunity to test this out. I do know that when one process tries to access another (which is interprocess communication, not what you were trying to demonstrate just now), that Kerio does protect against that by alerting the user and asking if he/she wants to allow or deny. Also, if I were to click this link in in Firefox, Kerio would alert that Firefox was trying to access the trusted zone (unless a rule is already set up), in which case, knowing that Internet Browsers should communicate with the Internet, and what business does it have accessing any files on your computer, than I'd simply block it).
No, it won't, because it didn't work.
Well, will you get a clue that that was never the argument. The argument was that you were being a mere child attacking others at any sign of ignorance, rather then trying to assist others, in order to boost your inflated undeveloped ego. Now that you had to try to defend your position, the usenet community that hasn't killfiled you yet can now see that you haven't a clue what you're talking about. Hopefully, this will pursuade you to lurk for a little bit and listen to the real experts, rather than spout garbage that may be harmful to the end-user should they listen to your rantings. In Summary: NAT Router=Hardware Firewall. Firewall=good (It depends on the FW, but I recommend Kerio, in addition to NAT Router). No Firewall=Bad.
People usually tend to ask for stuff about their wrong conclusion, not about the actual issues. After all, why is he twisting NAT and packet filtering is he's generally concerned about the trustworthyness of the installed software packages? That's already a big jump, in the wrong direction.
It isn't a "hardware" firewall, it's a NAT router. It might have a packet filter implemented, but without proper configuration it won't do anything. And for most implementation, one could say that a proper configuration is impossible.
Well, then please provide correct information. NAT and packet filtering are different things.
Well, then one should use a packet sniffer.
D'oh. That's a simple shell script combining 'netstat', 'tail' and 'sha1sum'. Anyway, why should an application change without expectation?
Why do you insist on calling it "protection" beside it not being such?
Port Reporter. Freely available from Microsoft. Sits in the background and logs everything, just like it should be.
Then you're are making such a recommendation. Kerio PFW will make his computer trivially vulnerable, if you like it or not.
Even more bullshit. You're implying that it would actually increase security. How should it do so? Magic fairies?
Huh? It does work if the application plays nice. In that case, it isn't needed in first place. So you like toying around?
Oh, what a bullshit. Since when is a firewall essential for a home computer's security? And where is the firewall anyway?
Cut it out. My system proves that you're talking nonsense about such nonsense being essential.
Again: A NAT router doesn't provide any security at all.
That's not a protection either.
Eh... what exactly should websites be security risks? Or attachments?
And why am I missing even the most really essential stuff like installing updates and minimizing privileges? You really don't have any clue.
");>>"%i"> Um...This link doesn't work the way you're intending it to.
This is no link. It's a cmd-shell command line.
Huh?
It doesn't. And I don't even know why it should. Or how it should keep an eye on everything. Seems like you really don't understand the problem at all.
Wrong again. Just use Windows Messages, OLE, DDE or other stuff. This has even been proven to bypass everything.
And, as demonstrated, you don't even need IPC at all - passive modification of the configuration data is already sufficient.
One again, you're talking nonsense. There is no link to click. You open up Firefox, and it will surf to the changed start page while also transmitting information, just like it did before.
WTF is a trusted zone in Firefox?
Ah, I understand: William = idiot
Now please, go away. You don't have any technical knowledge at all, and unless you're willing to learn, you'll just keep on spouting nonsense. I won't mind you, but please stop telling such nonsense to other people who don't know any better.
