ICS help please
Mar 30, 2005 4 Replies
Jump to replies (4)
ICS help please open original image
Hi everyone. Can someone please help with this. I have two identical computers and have Windows 2000 Pro in both. One access's the internet, the other is connected with a xover patch cable and file shares with no problem. Am unable to connect to the internet with second.
DHCP enabled on all 3 nic's. Seems that APIPA is addressing the xover nic's due to not being able to detect dhcp server. Have tried maunally seeting all fields in both comps with same outcome.
Any help with this would be greatly appreciated.
First comp
Second
Apaptors & Bingings
DHCP enabled... First
LAN #2
Why bother with cross over cables? Get a cheap router and stop diddling around with software connection sharing. Given most SoHo routers are around $30 it's a no-brainer.
Love being called a no brainer LOL I am setting it up this way, then once its set up (it should work, shouldn't it?) I will change it over to dial up where I will be using it on the road. I have a box full of wireless cards but just want this set up to work for now. I followed the set up shown in practallynetworked.com and it is so far from helpful, hoping someone here can help. David...
Yeah, trying to futz around with PC-to-PC connection sharing is just too much of a pain in the ass to make it worth anyone's time.
Also consider that most SoHo (Small office/Home office) also have wireless models. I've seen them as cheap as $50 (after rebates). Again, a no-brainer. Wireless isn't all it's cracked up to be in many residential situations. Many types of construction (new AND old) tend to block or otherwise degrade the signal strength. For anytime I'm doing serious work that requires full bandwidth between devices I always use a wired link.
The only setup help needed comes with the SoHo boxes. Get one, plug in it's parts and follow it's step-by-step instructions. Then it's just a matter of telling your PCs to use DHCP and rebooting.
