anyone know when x10 could first set the codes electronically?
May 03, 2006 10 Replies
Jack Ak
Transmitter or receiver? There are multiple types of X10 devices with "electronically" settable house/unit codes. Why do you care?
anyone know when x10 could first set the codes electronically? open original image
any idea when x10 or variant got the ability to set the house/station code electronically, and not have to use the wheel?
im looking for name/model of the earliest device, along with any owners manuals etc. for same.
thanks,
mark
IIRC, for receivers at least, Leviton was first about 5 or 6 years ago. Smarthome came out with them at about the same time.
thanks for the lead; thats very helpful.
any idea where i can get a owners manual/pdf? im looking for something with a date on it.
mark
Why, trolling for prior art in a patent case?
I have been using X10 LM-15 Screw-In Lamp Modules for a number of years. This unit "listens" for a few seconds when "turned on" and "learns" whatever house/unit code it "hears".
The instruction sheet for one I have is dated 11/98. That doesn't necessarily indicate an original release date.
I doubt this is the first X10 item to have no house/unit code setting wheels.
When did the socket rocket come out? I'm thinking it was around at least as far back as 1998. And didn't PCS have a no-dial switch in 1997?
Dan Lanciani ddl@danlan.*com
I thought things like the "socket rocket" have been around at least since
1998. The X-10 handheld MBR remotes set the housecodes electronically - they've been around for quite some time. My instruction booklet file shows the remotes existed at least as early as May 1999. IIRC, there's no code wheel on the CM11A and that's been around since 1998, at least according to a file sort by date in my X-10 online files. I'm not sure exactly what the OP wants to track:
1) first non-codewheel unit
2) proximity programming via Maxi console - as in the socket rocket 3) programming via button press sequence (like the EagleEye PIR transmitters).
I dimly recall a Bearcat 101 scanner that had sixteen lever switches in front that allowed you to set frequencies electronically by translating the binary numbers you entered via switch position. That's got to be at least
20 years old, maybe even 30. There's doubtless loads of prior art on electronic code selection, probably going back to the famous cryptographic machines of WWII.
-- Bobby G.
I think you're right about the socket rocket. That was probably the first one. Leviton followed up after that.
