ZoneAlarm upload picture to ebay
Nov 23, 2004 1 Replies
Have spent (wasted) most of this evening trying to upload a picture to ebay (with ZoneAlarm Pro as my firewall). My system just hangs - I don't get the small window telling you that your picture is being transferred. No error messages, no new windows, system just sits there.
Ok, now before someone says it - it's not a passive transfer issue as I'm using broadband. On ALL the ebay sites listed under Privacy of ZoneAlarm I have allowed EVERYTHING I can find. I'm running XP SP1, admin login, all other apps closed.
If I exit ZoneAlarm then I can update the same picture without any hassle so it's not an aol or ebay problem, it's due to the firewall.
HELP.
at last! :-)
I can now upload pictures to ebay using IE6 - remove the tick from 'Use Passive FTP' under Tools | Internet Options | Advanced tab
(so I guess it was a passive transfer issue after all....)
