ZoneAlarm firewall and LSA Shell lsass.exe. pls help
Jul 15, 2008 2 Replies
zonealarm firewall shows LSA Shell (Export version) wants to accept connection from the internet.
Application lsass.exe Source IP: 119.40.177.18 Port 500
can somebody pls expaling why lsass.exe wants to accept connections from the internet
That's for IPSec key exchange. If you don't use IPSec, you can set the PolicyAgent service to "disabled". Not providing services you don't want to be used is the best way to prevent them from being attacked anyway. No need to install crap like ZoneAlarm for that.
On Windows 2000 or XP you can use win32sec [1] or ntsvcfg [2] to disable services users normally don't need.
[1]
cu 59cobalt
to receive further instructions or data from whomever 'owns' you
